TwinTurbo.NET: Nissan 300ZX forum - The flywheel is hitting the bell-housing
Subject The flywheel is hitting the bell-housing
Posted by na300zx (OH) on June 08, 2008 at 12:42 PM
  This message has been viewed 172 times.
In Reply To NA trans on a TT. posted by ni[X]it on June 08, 2008 at 12:36 PM
Message I had the exact same problem when I did mine. Mine hit on the piece that is
thin and completes the hole for the started (the side of the hole that the
engine is on) and another spot on the same side but toward the bottom.
The best thing to do would be to take some machinist dye on the inside of
the bell-housing to find out where it is scraping and grind it down with a
carbide cutter. Make sure you spray WD40 or similar on what you are
cutting or the aluminum will clog up the carbide bit.
